ZX6 F3 (1997) rear wheel fitted to ZXR400 H1
Minimal modifications, swap zx6 wheel bearings for zxr400h wheel bearings, sprocket carrier bearing, circlip and dust seals are the same for both models.
Sprocket and brake disc are a straight swap.
Using 400H axle, axle sleeve and spacers, fit two 6mm spacers between caliper and mounting bracket.
Job done.
Only thing to sort is the rear hugger, have to raise it slightly.
Forgot to weigh wheels, the ZX6 wheel did feel a bit lighter.
