changing clutch cable
tink
- My Bike: ZXR400 L2
how easy is it to change a clutch cable on a L2 and mine has the wrong on fitted to it and also will i loose any fuild from the gearbox
Re: changing clutch cable
You wont loose any fluids if you do it properly. It should be just a case of slacking the cable right off, undo at the clutch lever, undooing from the mount under the clutch casing, feed through the new cable and then re route the new one the same way. You shouldnt have to undo any bolts, except for the ones holding the RHS fairing panel on.
tink
thats great news now i've just gotta order the right one
