Changing Import to UK spec? Need help..
wildkid
My Bike: ZXR400L 99reg
Post by wildkid »
Ive fitted Uk clocks, M marked CDI but was wondering if its possible to change the headlights and change the r/h switch so the bike has sidelights and the option to turn on and off the Lights? would they just connect straight in to the usual connections or what? Share some light please :)
gavinfdavies
My Bike: gpz500s d5, zxr400 L5
Re: Changing Import to UK spec? Need help..
Post by gavinfdavies »
it's possible, but the lamps are expensive, sidelights are useless, so why bother? I only know of two occasions when i turn my light off... track days, and when I'm trying to start it on a low battery! If you just want this ability, just put a little throw switch into the 12v feed line for the lamp, and put it on the little bits of fairing by the right bar. you're always best to right with you light on for safety's sake anyway.
but it could be done, with i expect a little soldering at most.
Neosophist
My Bike: VFR400R NC24
Post by Neosophist »
I did this, then took it off so.
Yes you can.
However, you need the loom for the sidelights as this wont be on the Japanese loom.
I believe the automatic headlights are controlled by the junction box, when I fitted a UK junction box to my JDM bike the headlights didn't automatically come on, but I had no switch so I couldn't manually turn them on.
I'm guessing that you could use the JDM junction box with either bike, as the headlight switch will over-ride the lights, but you cant use the UK junctionbox with the JDM bike as you wont be able to turn the headlights on.
Is there any real-reason you want to do this? With the auto-lights you dont need to remember about turning them on, other drivers will be able to see you better too..
wildkid
Post by wildkid »
Was thinking about doing it because then i wont have to find bulbs Plus keeping my lights on during the day time,
ill proberly keep it as it is then
Neosophist
Interesting.
You can get some adapter rings for about 10.00gbp.
They will let you use standard H4 bulbs quite easy (you can use them without the rings but the rings make it easier)
You should always ride with your lights on, its easier for cars to see you.
Most of the new bikes, CBR / ZXR etc have lights on when the engine is running anyway, you can't turn them off.
Tirpitz
My Bike: Kawasaki ZXR400L4
Post by Tirpitz »
I wouldn't worry about the bulbs blowing just because you've got the light on all the time. I've done 9000 miles on my bulbs and they haven't gone. IIRC my GPX250 did over 40000 miles and I changed the bulb once.
The bulbs are expensive when they do go - but then so is a funeral :smt002 I'd rather have them on.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
wildkid
Post by wildkid »
Tirpitz, what bulbs would you suggest? and also where and what ohlins steering damper did you buy to fit? and how hard are they to fit?
