Where does this wire go?
zxr400er
Post by zxr400er »
After a re-frame over winter I'm just putting the loom back in. This wire seems to be the only 1 I don't have a photo of where it went and its the only 1 I can't seem to find!!!
It comes off the same bit the fuel pump wiring is and has a ring terminal so I'm sure It's an earth but where did it originally earth to? :)
Miles
My Bike: ZXR 400 L3
Re: Where does this wire go?
Post by Miles »
Look behind the crank case breather pipe. I believe its the earth onto the engine. Should be a bolt
zxr400er
Post by zxr400er »
Theres already one on there which goes to the battery terminal iirc?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Goes onto the frame - you should find the location within reach of the wire, its part the main beams attach too.
You mean by the rear shock mount MM?
adriancowley
My Bike: zxr400L2
Post by adriancowley »
Hej,
On my bike, the BLK/YL wire attatches to one of the fule pump mounting brkt bolt holes; bolts to frame.
Took a pick as my bike is in surgury at present.
Loaded up a pic called wir_pic to junk stuff on gallery.
Hope it helps,
//Adrian.C
