Gasket, Air Fil ???
Miles
My Bike: ZXR 400 L3
Gasket, Air Fil ???
Post by Miles »
Hello, Asked Cradleys to send me the gasket between the carb and the airbox (Large rectangle looking one). Instead received 4 large o-ring shaped gaskets labeled , GASKET, AIR FIL Part No. 11060 - 1139
Are these the o-rings that sit under the inlet rubbers? does anyone know?
Re: Gasket, Air Fil ???
The one your after is here
http://www.zxrworld.co.uk/images/Lseries/lairbox.gif
However it's marked as part number 11060-1139 which is what you already have......................must be a mistake somewhere
Cant find a part number for the carb rubber o rings cos they have changed and are not on the ZXR world microfiche
Strange very strange
Miles
My Bike: ZXR 400 L3
Post by Miles »
Yes I thought so as well. The guy on the phone even said "Yes thats the large rectangle shaped one between the carbs and airbox" So I wonder if I have the wrong sticker on these gaskets.
According to the MF the part I want is 11060A but when u check the list that's what I've been sent?
Shall ring them in the morning. I was planning on getting new inlet rubber o-rings anyway so if thats what I've got happy days
Miles
My Bike: ZXR 400 L3
Post by Miles »
Had a look more closely at the MF and the 4 gaskets I have look the same as the 4 in the inlet rubbers but their labeled same number but ending in 'A'. I believe the four I've been sent are the same gaskets but mine are for the 4 gaskets under the intake trumpets on the carbs
Can anyone tell me if this sounds correct? In other words are there 4 round rubber gaskets under the trumpets? (I've never stripped my carbs as far as that)
Well folks Miles has a confession to make.....................
Come on Miles fess up,,,,,,,,,,,,,,,,,,,,,,,,, :pmsl
Neosophist
My Bike: VFR400R NC24
Post by Neosophist »
O rings O rings O rings.
Right.
If you take the bellmouth plate off the carbs (theres 2 screws per carb each side of the velocity stacks) you have an O-Ring under each one that seals the plate to the carbs, hence 4 in total
This is part 92055-1464
The later type inlet manifold rubbers have 4 o-rings underneath them too (however these are quite thin)
http://www.zxrworld.co.uk/images/Lseries/ltopend.gif
You can see them in the Top-End Fiche above
There part 9055-1521
I suspect you have the O rings that go between the bellmouth plate and the carbs.
11060-1139 is the correct part number for the large rubbery gasket that goes around the top of the bellmouth plate that the airbox seals against. Sounds like their packaged incorrectly.
If the o-rings are quite large (lay them around the velocity stack) and fat thats where they go :-)
If there small and thin there for the inlet rubbers. (later type) the L1 - L3 didn't have these.
I suspect you will feel a fool just like Miles does right now..............................when he finally confesses............come on Miles get it over with. :excited
Explain to everyone what a plonker you've been
And lets not forget to phone Cradely and say sorry......................and that Cargo figured it out................... oldman
:pmsl :pmsl :pmsl :pmsl :pmsl :pmsl :pmsl :pmsl :pmsl
Miles
My Bike: ZXR 400 L3
Post by Miles »
ok ok I fess up. I've been abit of a dick about this lol. But when you take a regtangle and coil it up it can look like o-rings......(Cluching at straws)..
Yes I rang Cradleys this morning and said sorry....Next time I think I'll open all the packets and then see...
And yes thanks to Cargo who solved this riddle
Miles 0 - Stupidity 1
I promise never to mention it again
NOT
Neosophist
lol!
You didn't open it and check it? shocking
Miles
My Bike: ZXR 400 L3
Post by Miles »
I know I know in my haste of getting other parts took one look in the bag, thought I saw 4 rings and rang cradleys at work, so didnt check till I got to cargos
lol :smt003
