"I looked at the ignition barrel whilst attached to the lead and noticed a metal plate just were the cable come out, so i investigated a little further to reveal that its a easy job to take that off and the little white plastic bit with the connectors ( which thank god only can go on one way down to the T shaped spindal it has to go back on ) then under that is a black almost circle with cut out tabs thing, which i pulled out to reveal that is what the cord is connected to. So now i have the ignition on its own without having to mess with the rats nest of cables around the bottom half of the airbox. Willl this work still if i get a key made up 2moro and assemble it back the way i found it????........"
I just need to find out if the electrics will still be ok when i have a replacment key made up 2moro or will it trip somthing out and stop working?? Any help would be very very apreciated.
Cheers,
and happy riding in this PERFECT!! April weather
