de-restricting zxr 400
jimbo
- My Bike: zxr 400
hi ive just de-restricted my zxr 400 by taking the restrictors out of the carbs,but it still feels like its restricted is there any other restrictors?
Re: de-restricting zxr 400
Is it a UK model or an import
jimbo
- My Bike: zxr 400
Its an import
- extonyg
- My Bike: zxr 400 L1 uk
if you do a search .........top right corner.............. theres loads of threads about restictions..........smaller 30mm carbs, cdi, speedo
jimbo
- My Bike: zxr 400
my cdi has these numbers on it 2119 1394 and its a yellow sticker is it restricted?
Easy answer is yes however it could be that somebody has overcome it.
But yes a yellow CDI box is a restriced one.
You should also see a 3 wire lead from your speedo that connects to the loom via a black connecter.
I'll post a photo for you if you like ?
jimbo
- My Bike: zxr 400
yes it has,would this effect the acceleration as well as the top speed?
OK I'll explain
You have an Import ZXR400 it is restricted..................this restriction takes to form of a speed sensor in the speedo that restricts your top speed I think it's 110mph. This is done voa the 3 wire black connecter sending a signal to the CDI that you bike has reach that preset top speed.
If you unplug the unplug black 3 wire connecter at the speedo the CDI box goes into a default mode and will not allow the bike to rev over 10,000
There are anumber of methods of overcoming the restriction all of which are explain in the various threads on this subject
A quick run through...........................
1. Replace CDI for a blue UK one or
2. Fit an after market deristricter or
3. Connect a 10 ohm resister across two of the wires at the black connecter I think it's the outside two or
4. Open the speedo and bend back the little tab that makes the connection at the preset top speed or
5. disconnect the speedo drive cable (illegal) or
6. Buy a UK ZXR 400
6. Buy a UK ZXR 400
jimbo
- My Bike: zxr 400
Mine struggles to hit 85mph? it also has a kph-mph converter fitted
Ah maybe it restricted to 110 KPH
jimbo
- My Bike: zxr 400
OK thanks for your help i will proberly look into changing the cdi
Funny enough I had a CDI problem yesterday.................watch this space
- Miles
- My Bike: ZXR 400 L3
That reminds me cargo I still have two of your CDI's. must get them back to you
to draw this all in to one place as the original thread was locked and i found this on an old thread ..
you want a 21119-1332, blue label, big "M" on it.
however.. if its fit the bike should pull over 85 whatever ignition is fitted.
kph or mph clocks ?
check it hasnt had tiny jets fitted when it was restricted, and that the air filter/airbox assembly is complete and in good condition.
answer to the above is "same as before" you have a 21119-1331 cdi, blue label, big "L" on it .. just another restricted import ignitionjimbo wrote:i just brought a uk cdi with the letter L on it whats the top speed?
kph or mph clocks ?
jimbo
- My Bike: zxr 400
hi if my down pipes are blowing a bit would that be the cause of my problem
