De-Restriction Method #3 - UK CDI
Locked
Method number 3. You will notice through all of the derestriction methods theres a common denominator, the CDI.
This thread shows the number of different CDI's available for the ZXR, i dont know which ones were for whick markets or what advantages they do or dont have, but they do exist.
viewtopic.php?f=55&t=5228
One thing i do know is that the UK CDI, that has a blue sticker and the letter M printed on, is not speed restricted. So if you have any of the other CDI's chances are you have a restricted model. you can undo this by fitting the UK CDI. However, they are not compatible with H model, so fitting one wont work. They will tho, work on L models with no modification at all. Fitting the Uk will also mean you do not have to do any of the derestrictions modifications previously mentioned, its simply plug and play.
Locked
