H & L owners, a bit of help needed
I'm wanting to make up some patch wires so need the following info'
The two block connectors going into the CDI , I'm needing to know the location of each coloured wire - what the wire connects to isn't essential but still appreciated too, I'm sure I can look it up in the forum workshop manual.
So looking at the block connectors like this (not the cdi) :
(open in new tab for larger pic)
For example
1. = Black
2. = Green
3. = Red
ect......
Cheers,
MM!
For example
1. = Black
2. = Green
3. = Red
ect......
Cheers,
MM!
Re: H & L owners, a bit of help needed
From a Jap import L model
1. black/white
2. blank nothing no wire attached
3. green
4. black/ yellow
5. green/black
6. black
7. black/white
8. pink
9. yellow
10. gray
It would be good if someone could double check this for you just to be sure
1. black/white
3. green
4. black/ yellow
5. green/black
6. black
7. black/white
8. pink
9. yellow
10. gray
Cheers C,
Hoping to get a few results in , hopefully they will not all conflict
Drew - from a UK L model ( I have two spare looms and they both check out)
1) Brown
2) no cable
3) Green (2/3 coil)
4) Yell/ Black (earth)
5) Green/Black (connected to earth)
6) Black (1 /4 coil)
7) Black/white (ignition pick up)
no cable
9) yellow (ignition pick up)
10) Grey (connected via resistor to live)
these are the colours as though I was looking at the teminal block with the cables coming out the other side
1) Brown
2) no cable
3) Green (2/3 coil)
no cable
Thanks D,
Pink is confirmed as the speed restriction signal and the F3 cdi's seem to ground this out - I'll be pissed if that's all these freakin black boxes are doing
Need to investigate further......
Dave:
1) Brown
2)
3) Green - regulator
4) Yell/ Black - Common Earth
5) Green/Black - earth
6) Black - #1,4 coil
7) Black/white - pulsar rotor
9) yellow - Throttle sensor
10) Grey - #2,3 coil
Cargo:
1. black/white ?
2.
3. green - regulator
4. black/ yellow - Common Earth
5. green/black - earth
6. black - #1,4
7. black/white- pulsar rotor
8. pink - clocks
9. yellow - Throttle sensor
10. gray - #2,3 coil
Dave:
1) Brown
2)
Cargo:
1. black/white ?
2.
6. black - #1,4
8. pink - clocks
Further update...................
There are 3 wires coming from the speedo box of tricks.................
Brown
Black/yellow
Pink
These seem to be numbers 1,4 and 8 in my list there is certainly continunity between them at each end..............could be going via something else
Hate electrics absolutly hate em
Brown
Black/yellow
Pink
- My Bike: ZXR400 L1 trackbike
PROBLEMS!! Rewired my bike to a race loom & total loss. Now she just won't spark!! The really strange thing is that the cables going into the certain terminals are completely different from yours!?!? I did have a Red "A 1271" CDI, but I've just changed it for a Blue "M 1332" CDI.
On my bike the terminals are;
1-No cable
2-Yellow (Rotor Sensor)
3-Black/White (Rotor Sensor)
4-No cable
5-Pink (I've got this off tho)
6-Green & Black (Connected to live via 100Ohm 0.5w resistor)
7-Brown (Red on my bike for some reason)
8-Black (Ignition Coils 1/4)
9-Black/Yellow (Earth)
10-Green (Ignition Coils 2/3)
The bike was working before I touched it so it wasnt me that put the cables in those terminals.
1-No cable
4-No cable
Lachie Innes #99
- CaNsA
- My Bike: ZX6R F1
I'll take some pics from the looms I have 2moz matey
Lachie,
Problem here is you have an H loom and an L CDI. If you have wired the race loom as per the diagram on the thread then if the wiring is correct you should be able to make the L CDI work - however you will need to change the postion of the cables into the connector block
Looking at the connector blocks as per your drawing (ie numbering as per facing the CDI) the L loom would be
1) Green (coil 2/3)
2_ spare
3) brown (live)
4) Black (coild 1/4)
5) Green/ black - connected to earth
6) Yellpow/black (earth)
7) spare
black/ white ignition pick up
9) Grey - connected via 100ohm to live
10) yellow - ignition pick up
1) Green (coil 2/3)
2_ spare
3) brown (live)
7) spare
Cheers chaps! Yeh that seems to be the case & hopefully that's me found the problem now after all the stress Ive been through!! lol I'm off tomorrow so will give it a crack first thing & let you know!
Thanks again!
Thanks again!
Lachie Innes #99
hehe .. thats why i bought an L1 loom for my H1
Id say they do ground the pink wire out MoriMan, usually through a resistor. I did workt his out to be 36K resistor but ive read others using a different value.
Successfully made a patch lead to run the H on a F3 Race CDI, it was a bit of a getting it sussed though!
However the same patch lead wont get the SP CDI's to work must be something to do with the fuel cut off solenoid but my head was bursting enough and ultimately happy to get the F3 box working on the bike
I'm tempted to lash in a set of SP cam's into the H2 motor just now while I'm building the SP engine back up.
MM!
MM!
She's alive!!! Changed the conections on the CDI which were completely different & the beast was roaring!! Noticed it idles at 4000RPM now tho! lol Not too bothered about that too much tho as it's a race bike & wont really be sitting below 10,000RPM at any time. Just happy its runnung for Knockhill on Sunday!
Thanks for your help chaps!
Regards
Lachie
Regards
Lachie
Lachie Innes #99
- My Bike: ZXR400 H1 '90
Hi,
I have an H1 ZXR 400.
I want to replace my 10k limited CDI red label (1271) with an M one (1332).I was reading about this action on the forum and I know that I must to do the following wires changes:
And I have a few questions about it:
1) I don´t know what to do with the terminal number 6 (on CDI 1271), should I swap to number 9 on CDI 1332 or what ?
2) May I use a resistor ? Why ? my bike is a street bike, not a racing one, so, is it really necessary ?
Thanks for your help in advance.
