tyre pressures
- My Bike: zxr 400 x 3
tyre pressures
can anyone tell me pressure for mich pilot front soft 120 70 17 rear med 160 60 17 . race pressures , not road thanks Sorry i did mean power one thanks for reply
Re: tyre pressures
I've not used Pilot, but have used Power One. For them (as for most 160/120), 30psi front and 28 rear should be a good place to start in the dry. 35 for both in the wet.
- My Bike: kawasaki zxr400
Re: tyre pressures
what did you think of the power ones,i am thinking of using them in the manx this year,thanks.Ian
Re: tyre pressures
They were pretty good. Got up to temperature quickly and no worse grip than Supercorsas. I thought the wear was a little bit quicker than on the corsas. I did one meeting with them (qualifying and 4 races), plus qualifying and 2 races and the rear was gone (bits torn out on right side). I was still more or less on my best pace time-wise, but the rear was sliding around a bit. Normally I get a another race or so out of a rear.
The front is pretty good - it is the V-type, which feels odd as you tip in, because the profile is higher (hence the 'V'), but then the contact patch is bigger. As per usual, the wear on that is less than on the rear.
And they're £60 cheaper than Supercorsas. And I got my best ever results on them (not time-wise, but position-wise
), so I'm a fan so far.
- My Bike: Triumph Daytona 675
Re: tyre pressures
I run 27psi front and rear for racing.fatboy wrote:can anyone tell me pressure for mich pilot front soft 120 70 17 rear med 160 60 17 . race pressures , not road thanks Sorry i did mean power one thanks for reply
