You've got to be kidding me!?!?!
saka_ZXR
My Bike: Kawasaki ZXR 400 L3
Post by saka_ZXR »
Right well i went out on my bike today and everything was fine, i rode about 40 miles and on my way home came to slow down behind a car at a roundabout and the bike just cut out, the dashboard lights went really dim then went out and i now have no electrics whatsoever on the bike. As i got off to have a look i noticed a strong egg like smell and a high pitched whistling coming from somewhere on the bike, i checked my oil level and it was fine but there was no coolant in the rad which is strange cuz the whole time riding id be glancing at the thermostat and it was sitting just above the blue cool bit and just below the first line on the thermostat.
Im gonna get in the garage now and check all the electrics, any ideas what could have caused it?
Wabby
My Bike: ZXR400
Re: You've got to be kidding me!?!?!
Post by Wabby »
Exploded battery maybe?
That smells like egg.
The sulphur you can smell is either your starter solenoid or your battery, judging by the symptoms of cutting out and dying on you i would say your battery is shagged, which could be a result of your generator packing up.
my guess is battery.so check your battery voltage and then check your battery electrolyte levels before the solenoid.
saka_ZXR
Post by saka_ZXR »
Well ive just tested the battery and its only giving out 5 volts, ive slapped her on charge.
the battery looks rather new and its a sealed varta battery so cant top up the electrolytes.
Gonna check the alternator once theres charge in the battery.
saka_ZXR wrote:Well ive just tested the battery and its only giving out 5 volts, ive slapped her on charge.
At 5 volts your battery is fooked and any hope of recovery could only be managed with an Optimate or simiiar..........even then it's highly unlikely to be recoverable
yep that battery is well and truly shagged!!
saka_ZXR
Post by saka_ZXR »
Right new battery time then.
Desont look like i'll be going to scotland this weekend :(
need to get a new battery then find the electrical problem by tomorrow night =/
U reckon its the generator not charging the battery?
saka_ZXR wrote:Right new battery time then.
Certainly something is causeing the battery to lose it's charge...................could be rectifier or generator...................it could also be over charging the battery
It shouldn't take too long to spot the problem and fix it
saka_ZXR
Post by saka_ZXR »
Well managed to get my KLR back on the road so can always use that if i cant get the zxr running :D
Gnna go get a new battery first thing tomorrow whack it on charge for a few hours then test the regulator and alternator :)
*fingers crossed* ill have it sorted by tomorrow night :)
parby81
Post by parby81 »
test them both as per the manual. The genny is really easy to do just make sure you remember to put your volt meter on to AC current!!
saka_ZXR
Post by saka_ZXR »
Well i have a specific alternator tester which doesnt need changing, the lights light up on the front and tell u if its working or not :D
