Is it just a matter of disconnecting all the pipes leading to the engine etc and just blasting a hose down the the top end at the filling cap?
Green liquid leaking?!?! Bubbling coolant water?!?!
saka_ZXR
Re: Green liquid leaking?!?! Bubbling coolant water?!?!
Lemme just make sure before i go fucking everything up, like i have a tendancy to do
- hciR
- My Bike: zxr 400
If you just wanna test the rad, dissconnect the big hose near the rad cap, and the one on the other side. Then pour water where the cap is and see if it comes out the other side.
saka_ZXR
But wouldnt that only test for a leak?
Baz and rob suggested i flush the rad out to get rid of any sludge.
Davw
Mate- you can do this with the rad on or off the bike. Best to take it off but if you are short of time then diconnect the supply and return lines (if you tie or tape lines up you wont need to drain the system - altyhorugh to be honext if the system is dirty then drainign it wont hurt) then use a water hose to (gently initially) flush through the radiator.
It probably goes without sayiing that if you use hot water from a kettle and let it sit for a while then that will tend to loosen up any toad that is in there - however for that to work you need to temporarily block the outlet (some gaffer tape will do it) to keep the hot water in the rad. Then when its all nice and loose - flush it through with a hose in the filler cap until water is floowing freely. If there is still carp in the system then repeat
there are proably proprietary solutions for flushing radiators - havent used them myself so not sure how effective
Davw
Carp!!!
. If there are any of those in there you have found the problem
saka_ZXR
Nice one mate I'll give it a shot tommorow
saka_ZXR
Right well i gave the rad a huge flushing out 2day and filled it with fresh coolant and water, took her out for a nice big run and gave her abit of a ragging at parts to see if shed get really hot again, pleased to say she didnt
Problem solved
I also noticed shes running quiter now, well she wasnt bad just abit of a deep glugging on idling which has now stopped
I actually cannot thank you guys enough for your help
If it wasnt for u lot pointing it out then i wouldnt have had a bike for my trip to scotland this weekend.
Im currently on the jobless list but as soon as i get back on my feet i will DEFINATLEY be making a donation to the site
How much does it cost to run the site for a month baz?
Once again thanks to all the lads who helped
£20 a month mate , used to be £75 a month but i upgraded recently
make sure you recheck the coolant level now you have ridden it a bit.
saka_ZXR
Ahh nice one baz
Jesus £75 a month is steep! Good job u changed it :p
Have been checkin the level everytime after I've riden it after it's cooled down, went down about an inch or 2 at first but that was expected as the coolant went round the system
