Fitting H model wheels to an L model - I'm stuck
Max4music
My Bike: zx7r / zxr400
Post by Max4music »
I'm sure this is an easy one for all you seasoned zxr400 lovers. I bought a spare set of wheels for my track zxr. Popped em in no props, an have used ok. The other day I decided to change the wheel bearings so set about dismantling them only to find a washer next to the bearing that isnt shown in the manual. Now with it removed the wheel is sloppy. Ive measured from the bearing to the outer of the hub and have found there is about 3-4mm difference between this and the original wheel. Upon closer inspection I notice slight differences in the wheel. I have concluded that they are zxr400H wheels and someone has bodged in a spacer at some point. Does this sound correct? Has anyone else swapped the wheels? I'm looking at getting a spacer specially made to solve this. ha anyone else done this and can you confirm exactly what size it should be? A Colleague has offered to turn up a new right side "top hat" spacer if I can give him the exact dimensions.Thoughts please
Re: Fitting H model wheels to an L model - I'm stuck
done the reverse and have fitted L wheels to an H, needed to cut a couple of mm off the spacer and it was all good..
thinking about it ... if we swapped my L wheels for your H wheels.. neither of us would need custom\bodged bits :smt002
just a thought .. pm me if interested.
hey Zimm
If maxmusic not fancy the swap, i will swap ya my black h1 jobbies.
Im afraid im going to the other side :smt010
gonna try the L
works for me Jake.
the L is probably the better bike for track tbh.. twitchy though
Max4music
Post by Max4music »
zimm wrote:done the reverse and have fitted L wheels to an H, needed to cut a couple of mm off the spacer and it was all good..
Hi mate, sound good Ive sent you a message
Max
will#224
My Bike: L1 racer
Post by will#224 »
I'm splitting a race bike and have 2 sets of wheels in good condition with cush drives etc. I would swap for L wheels and throw in a few sets of new renthal sprockets as a sweetner
