Are the needle rubbers up top of the carbs all ok? not perished or split? Properly seated etc?
O Rings in the inlet rubbers
Re: O Rings in the inlet rubbers
stug
- My Bike: Yamaha R1
Had the same problem with my wifes after rebuilding the carbs and doing the shims.
The last thing that I replaced and it sorted the problem was the mixture screws.
One looked like it had a slight bend near the tip.
Although this could probably have been fixed by messing about with the screws.
