"If it's not broken, fix it 'till it is - If your not sure how it works, take it apart and find out - If it don't work when you put it back together.......look in the manual"
i think you have gotten confused with oli's reply there. You can get the H model rear end to fit, but with mods. Its not a straight swap as the L and H have different sub frames!
