Ignition?
Delen
Ignition?
Post by Delen »
hi,
so got my prob. with the cam fixed..
anyhow stuck the cams back in and the tensioner everything lined up nice, pulled it round a couple of times and the cam chain titend up now it dosnt line up anymore. the pic is the ignition plate when the marks on the cams them self line up ith the engine at the top.
Leave it, change it?
thanks =)
You Don't fail until you give up!
parby81
Re: Ignition?
Post by parby81 »
undo the tensioner (completely) and line them all up again, make sure you count to the 30th link as in the manual. Its worth doing it again just to see.
Delen
Re: Ignition?
Post by Delen »
parby81 wrote:undo the tensioner (completely) and line them all up again, make sure you count to the 30th link as in the manual. Its worth doing it again just to see.
Thx, for anwsering. Mayby I'm just dumb but do I only have to remove the tensioner? dont I have to remove cams agine? and what do you mean count to the 30th link? cant find anything like that in the manual :smt017 :smt001
by the way the manual says not to turn the engine without tesioner so I would have to line the plate up remove tensioner and cams reinstall lining them up agine, reinstall the tensioner and turn the engine in hope of it still being in line agine..
an option I see is removing the plate and shifting only the plate, but dont know if its possible. :smt017
Re: Ignition?
change it mate, if all 3 marks (rotor plus cams) dont line up, its not right.
set the rotor to the right place, remove tensioner, remove cam-caps, re-align cams, reinstall cam-caps, reinstall tensioner.. check alignment.
repeat until correct ..
the 30 links is from cam mark to cam mark, try to keep all the slack where the tensioner would be (IE front run is tight)
Delen
Re: Ignition?
Post by Delen »
zimm wrote:change it mate, if all 3 marks (rotor plus cams) dont line up, its not right.
damn wont work :( 4th time now. line up the Ex nice and tight then put the In in counting 30 links which also lines up nice but there is a lot of slack from cam to cam put the tensioner in and turn it over and tada I end up just as the pic posted before every time :smt017
Undid the ignition plate but unless I make a new track in it there is only one way to have it in :smt012
Delen
Re: Ignition?
Post by Delen »
ITS A MIRACAL!!
Went to do it once more.. tock the tensioner and ops the plate was wrong o well put the tensioner back in to turn the plate right.. and bingo turn the engine and when the tensioner was right everything just lined up lovely. I dont care why it worked all of a sudden just glad it did :smt003
