Pulling to the right.
- My Bike: zxr 400 h1
Re: Pulling to the right.
Do you mean wear? If so no. The speedo driver is playing up and there is sqeeking from the rear. Have sent it off to the mechanics now so hopefully when I'm back from Gran Canaria all will be well.
Action is the antidote to despair.
- My Bike: zxr400 L9
id check you rear wheel is straight, it only has to be out a bit to make a huge difference, also dont take this the wrong way but have you put the wheel in the right way round, tyres only work in one direction.
never give up!
you cant do that on the zxr because of the spacer on one side and the speedo drive on the other, they wont interchange allowing you to put it in the wheel in the wrong way
