ZXR400 piston pin size
kawakay
Post by kawakay »
Does anyone know the piston pin diameter?
I checked workshop manuals but there is no
information regarding this. All pistons
1989-1999 use same diameter piston pin,
since them share same piston pin clip
92033-1151.
Can someone measure the piston pin
diameter either from piston or piston
pin? ZXR250 uses 13mm pin so ZXR400
most likely has bigger pin.
Thank you
mpotnoodle
Re: ZXR400 piston pin size
Post by mpotnoodle »
just measured one in my shed it is 40mm long and 15mm wide if thats any help to you
mike
