Hi all,
Pretty new to this but been reading a few post which have helped sort out some of my problems thanks! However I have just a small problem in locating the position of the flywheel!!! Was wondering if anyone could point me in the right direction as to where it is???
And also if anyone has removed one before would you be able to help us go through it???
Flywheel
- U_h0rnet5
- My Bike: ZXR400
- My Bike: Unique ZXR400
Re: Flywheel
To be more specific, its on the left hand side of the engine behind the engine cover (its got ZXR printed on it if you have the L model), you will need to drain the oil tho before you remove it.
- U_h0rnet5
- My Bike: ZXR400
Re: Flywheel
Clever cheers guys
Will i need to remove the engine to change the fly wheel???
