Anyone else had this problem? The engine noise is beginning to pss me off at red lights!
gonna start calling you RedexRobBRobB wrote:Thats a typical problem with some ZXR's, you come upto the lights and its revving higher than it should be then dies down. No idea what it is tho, try running some Redex through as well as everything else thats been mentioned.
try it and see?RobB wrote:i quite like that name, can i change my own name in the ACP?
Maybe you should mention this at the next Redex Board meeting Rob? could make your shares worth a little moreCaakman400 wrote: Not so sure if I can buy Redex in Japan...will find the nearest equivalent
how does one do this?zxr_oli wrote:Mine used to, until i richened up the idle mixture a bit.
