What Swingarms have people fitted??
hi guys what swingarms have people fitted to the zxr400 to try and get a bigger wheel in ???
Re: What Swingarms have people fitted??
Umm, dont think anyone has ever done that, except a member here who fitted a VFR800 single sided swingarm but thats for show. A larger section rear tyre will actually slow turn in speed.
hey rob..
i can understand what your saying...
but iam ging to make this a race bike... with an RZV500 V4 500cc two stroke in it
and i can make it turn in quicker if i wanted too, when i fit a 180 rear i can jack up the rear a little and drop the forks as well to counter act the wider wheel...
the bike should have 130hp at the rear wheel...
take a look at my friends bike he started
http://www.gareth.evans9.btinternet.co.uk/zxr500.htm
what do you think??
what do you think??
yeah weve disucssed this here
viewtopic.php?f=1&t=4637
Sounds like a plan you have there! Like i say as far as im aware no one other than this guy has fitted a larger rear tyre
viewtopic.php?f=50&t=2801
- jake
I know a couple of american zxr400 racers use 180 rears, but more cos of the better choice of rubber.
You can get a 180 in a standard zxr400 swingarm no probs, The early zx6r wheel goes in with a bit of this and that im told. There is probs others that will go to.
from what ive been told a 170/180 will fit in the stock swinger .. depending on the rim its fitted to.. (ie, how "pinched" the tyre is)
to be honest my zx6r engined zxr has 115bhp at the wheel, and i havent really noticed an issue with running the stock sized 160..
- Ballsout Racing
Yep, a ZX6 wheel with bearings to fit the ZXR400 spindle will fit, just then need to get some spacers made up. Oh, and may need the caliper hanger machined down a bit. Even the 400 sprocket carrier fit with the right wheel. Although I have seen a wheel fitted without any spacer on the right side, just bearing straight onto the caliper carrier.
ps, I don't know which model ZX6 wheel though
No need to change the swingarm, my 05 ZX6rr swingarm was narrower than my 400 swingarm by a few mm's. Wonder what it would take to swap them? Hmmmm.
