Rejet in progress...need a lil help
- colin155
Hi,
after an airbox mod i'm rejetting my bike ( zxr 400 my97)..i think i'm very close to the good setting.. but. being so close also mean that is difficult to understand some situations..
so..... does anyone rejetted his bike after some kind of mod?
i'm running on 115 mains...and seems to be pretty good but i always fear to run lean ....
byye
byye
Colin
on Kawasaki ZX4-R Eve
Forever Green ...
Green like Envy ...
Forever Green ...
Green like Envy ...
Theres a couple of guys on here that have mad that mod, solmansoft and il4 being the two i remember, so they will have more details for you.
Thing to remember tho its better to run lean then weak, the petrol is used to help cool the inlet valves as it passes, so running weak can cause over heating
Just to worry you some more
- colin155
for now i've removed the scoop and the rubber spout (sorry but remember english isn't my mothertongue) in the airbox intake.. fitter a fiberglass plate with "less restriction" velocity stacks
but.. this is a "try"... the dream is to fit a ram air like yours!
so.
if you want to tell me some... that would be great!
so.
Colin
Forever Green ...
Green like Envy ...
Forever Green ...
Green like Envy ...
il4
- My Bike: ZXR400L7
Do you have a picture of your Velocity stacks for me to take a peep?colin155 wrote:for now i've removed the scoop and the rubber spout (sorry but remember english isn't my mothertongue) in the airbox intake.. fitter a fiberglass plate with "less restriction" velocity stacks![]()
so.if you want to tell me some... that would be great!
I have removed the air scoop in the air box....hence its grossly lean on the main.
I'm currently running on #120 mains, 0.5mm shimmed needles and #40 pilot jet.
The pilots jets are definitely out....the low end crap!
I juz had a track session on good friday, and i realise I'm still running slightly lean on the main jets, juz bought #122, i will keep u updated when it try them....
I'm from Singapore...
if you find my carburation unusual, maybe you can use the climate data of my country as reference
http://app.nea.gov.sg/cms/htdocs/article.asp?pid=1088
Guest
Hi!
i don't have pics..but i can make some! so.. write me a pm with your email and i'll send you the pics.
my bike has a similar "setup" but now i've fitted 130 mains ...
but i still got to test 'em ! i've just take a lil try the day i fitted em and.. no more..'cause still raining hard!
if you know where to found my climate data... i'm from nord italy
Guest
ram air
Try emailing sloweracing he runs a http://www.bbplastics.co.uk ram air box on his race bike.
tk400
- My Bike: ZXR400 , ZXR950
sloweracing
Mine is a Race bike producing over 76 bhp so it's a bit different but should be same to set up so here is some tips
JETS 115 main
Blocked off air correctors
BB plastics air box ( http://www.bbplastics.co.uk )
If you block the air jet it settles the bike down and is easy to dyno setup
if you are running a mod air box i would block off the air jet and run a 100 or 110 main jet but would recomened a dyno run it's not good to keep guessing it could cost you a engine
Ram air box buy one you wont regret it then you can start playing with
stacks mine are still standard dont need the extra power at the moment
takes to long to get to a dyno and set up winter project for next season
Good luck
JETS 115 main
Good luck
- colin155
thank you mates!
i haven't never tried to block airjets.. anyway...maybe i've found the correct setup!
now i'm running 130 mains and the bike now seems to be perfect.. with lil jets the bike runs bad at full throttle...
reducing the airflow.. the bike became rich so... guess is right
Colin
Forever Green ...
Green like Envy ...
Forever Green ...
Green like Envy ...
- colin155
yep... i'm running stock airfilter on my bike!tk400 wrote:Are you guys running air filters with those jet sizes?
I used to use 125's with no air cleaner and a deristricted airbox but am strugling to jet my flatslides with out the snorkel and with an aircleaner.
I would like to see the airbox mods and velocity stacks aswell
please![]()
Colin
Forever Green ...
Green like Envy ...
Forever Green ...
Green like Envy ...
tk400
Still would be interested to see the velocity stack setup.
I would like to run shorter stacks because sp ones are longer than even the standard ones this is not working well with a four into one exhaust.
I would like a more peaky machine. I did read that some people cut the stacks flush with the top of airbox adapter.
Slowerracing, I have probably asked before on another site I think, but
have you got flatslides with that setup.
And am i correct in saying that by blocking the air jets you stop emulsification in the emulsiontubes therefore creating a denser fuel and hence you 115 jetting may well be equivalent to something much larger with out these blocked. Does this tactic stabilise the jetting because the emulsion system is a little inaccurate. And because the fuel is now denser(no emulification with air) does this mean you would need to drop the needles several clip positions.
PS SLowerracing that bike sounds like an absolute beast with that HP level it would compete with 600's!
cheers,
cheers,
sloweracing
It would if i could ride it harder there is alot of 400 in the bemsee chaimpionship producing good horespower
my jets sizes unblocked would be 132 main jet
No we cant run flatsides in bemsee
Didnt need to drop the needle as i am racing a H model and there dont have or i havent got ajustable needles just lucky really on the setup my dyno chart that i have is really good as well not sure if it is down to a very good engine tuner and the care and the time that has been taken to get the horse power out of the old girl
Brands hatch this weekend to do some more testing saturday and sunday
if any of you get bored pop along watch some racing and have a few beers
