Ok, the problem is, everything works fine untill you put main beam on or flash, the high beam stays on untill you switch off the ignition!
I have taken the dimmer/ pass switch apart and cleaned all the terminals etc, and i have swapped the relay and it hasnt cured it! you can hear the relay click on but not off?
Please help!
						Need help- Headlight problem!
				Dolts
check your earths and battery mate believe me!
				Long
				sloweracing
Welcome to the best forum for the ZXR
http://www.sloweracing.co.uk
Powered by
http://www.zxrworld.co.uk
Powered by
				sloweracing
