Indicators packed up
				crashtester01
coming home from work and my indicators packed up not a big prob i no but im as technicaly minded as a fish and i aint got a clue where the flash unit thing is can eny 1 tell me
									I can fly..........ouch that hurt guess I cant. wheres the bike gone!
bloody hell this brings back memories, coming back from minehead up the M5 the bloody indicators kept packing up, if i remember right the flasher unit is on the right hand side under the main seat, you will probably find a loose connection there.
				crashtester01
cheers but no luck as i dont no what the bloody thing looks like checked all the conections I could find but still no luckalso noticed that the solanoied (think thats what its called eny way silver thing on the left hand side with a fuse in it
  ) is a bit nackered its plastered in tape and the fuse is glued in god only nos why think its time for me and the zxr to part company before it robs me of evan more cash
there should be a flasher unit on the right hand side, its a cube with 2 wires going into it, mine kept coming apart so wrapped it in tape, that's whats wrong mate or the flasher has gone.
					Last edited by masterofinsanity on Mon May 08, 2006 4:06 pm, edited 1 time in total.
				Bikerz
Im the expert on flasher units
its on the right side under seat, take fairing off on the rear , ur see a black box about 4cm by 2 cm cliped onto the frame with 2 wires going into it, that ur flasher unit, i just recently canged mine for a LED one, if u cant find it turn ur indicator on and u should be able to hear it click (if ur in a quite place) let me knoe how you get one
Sheldon
Sheldon
				crashtester01
				Bikerz
if u need a new flasher unit mate, if u broken yours then u can  have my stock one as i dont need it
				crashtester01
				crashtester01
				mongo
- Xphyral
I replaced all the block plug pins on my loom when i got my bike.  The electrics would cut out whenever i turned left.  After removing tank and airbox had a look at the block coming from the barrel and all the pins in it were pretty much corroded to dust.  Just got an electrical crimper set from B&Q and went and replaced everything on the bike.  So if you get an old zxr and your having electrical probs check all your block plugs for corrosion,  their very easy to replace and only costs you 20 quid and a little time
