Repair/replacement of valve diaphragm rubber
Monsterter
- My Bike: Zxr 400 h2 1990
Hi im from philippines, i really need your help guys. If there are possibility to repair our valve diaphragm, or alternative rubber to replace the rubber only. Hope someone can help me.
Ewetea
- My Bike: ZXR400L5
Re: Repair/replacement of valve diaphragm rubber
You need to provide more details of the "diaphragm" so that we can understand what item it is. Is it in the carburettor, fuel pump...?
On the HOME page of the zxrworld website there is a section: "microfiche". Press that and then again on the H model. Then look at the exploded diagrams for your item to give us more information. Note that you have an H2, and this set if for an H1, but it should still be sufficient to provide more information.
do you mean the valve stem seals in the cylinder head?
Monsterter
i uploaded some picture. Based on the microfliche the code is 16126. I checked price tag at kawasaki parts and wow very expensive. 180 USdollars.
Monsterter
For temporary; my mechanic applied some flexible tape on it. for now the my bike still running. I really need your help guys. if there are suggestion or opinion regarding alternative way or alternate parts that can apply to my zxr 400 h2. thank you very much
- Dominik
- My Bike: Zxr 400 L3
Basically most keihin cvk parts will fit each other. Just check which models have those cvk as carbs and try to get some repair stuff there, maybe even a used but working carburetor. You can get them for less then 100£ on eBay in very good conditions
Zxr 400 SL - 130kg
Monsterter
Thanks for the info dominik. Tytyty
Monsterter
I just bought new rubber diaphragms from NRP.
