Hi,
When I am on the brakes hard I get a shake through the bars then as I slow down it is still there slightly.
I have checked headstock and they are fine also checked discs aren't warped and they are ok too?
Any suggestions?
Regards
Brake problem
- Restricted
- My Bike: zxr 400 l6
Re: Brake problem
Buckled front wheel? My rs125 gad a distorted tyre on the front where it had been sat for so long and did the same thing?
Re: Brake problem
how did you check the discs? you would need a proper runout tool i believe? the slightest warp not viewable by the human eye would cause shake at braking, have you checked your wheel bearings?
Re: Brake problem
You need to be looking at everything at the front end that moves.
Could even be something wrong with a brake pad
To check disc runout tape or cable tie a nice fixed pointer onto the fork leg ( a small screwdriver for example) put the tip of your pointer close to the disc..............now spin the wheel and watch carefully to see if the disc moves away from or towards your pointer.......................
