zxr400 1993 cdi unit
- My Bike: kawasaki zxr400
Hi im wanting to replace the cdi unit on my bike the only problem i have is my bike is a uk bike and the label in the cdi unit is blue with the letter M on it do i have to get an exact match or is there another i could look out for to replace it with as the 1 i have seems to be abit rare n currently broken thanks
Re: zxr400 1993 cdi unit
a CDi with a blue L or blue M will be fine.
Unfortunatly a cdi with an 'L' on will NOT be 'fine' it will limit the bike to 10.000rpm unless you fit an ' M Max box' or a 10k resistor. Your wiring will need slight modification to suit. Obviously a straight replacement 'M' would be ideal.clarkiefez wrote:Hi im wanting to replace the cdi unit on my bike the only problem i have is my bike is a uk bike and the label in the cdi unit is blue with the letter M on it do i have to get an exact match or is there another i could look out for to replace it with as the 1 i have seems to be abit rare n currently broken thanks
R.Middleton
Ahhhh damn ive been offered a yellow labelled 1 with a v on it the blue label with the m seems awkward to find
rodger, he is on a UK spec bike, with mph clocks so he wont have the pink wire to the clocks...i have always been under the impression (and its also reiterated in the restrictd zxr's section) that uk bikes were not speed restricted in any way, and that the L box and M boxes are almost the same, with the M having a slightly higher redline?
im not a fan of quoting cargo...but i think he thinks the same as me on this...
viewtopic.php?f=125&t=15664#p113885
from the other week...
banner001 wrote:im not a fan of quoting cargo...but i think he thinks the same as me on this...
No he doesn't....................UK CDIs are not restricted and Jap market CDIs are
ok, simple question, are the blue L and blue M CDi's restricted in any way?
edit: as far as i have been told there are 3 "non sp/kit" CDi's
21119-1394 - Yellow V CDi - import and speedo restricted, 14,500 rpm
21119-1331 - Blue L CDi - UK and not restricted, 14,500 rpm
21119-1332 - Blue M CDi - UK and not restricted, 14,800 rpm
but as there is SO much missinformation, maybe its time to clarify this...
- My Bike: zxr400
banner001 wrote:a CDi with a blue L or blue M will be fine.
Why do you advize people wen you dont kno the answer, it looks like you just guess alot of the time. Thats not helfull in anyway.banner001 wrote:ok, simple question, are the blue L and blue M CDi's restricted in any way?
its has been stated many times before that the blue L and blue M CDi's are NOT restricted...thats what i told the OP and was then told that i was wrong...which i dont think i am, i would like this clarified by someone who has more influence than i.matthew wrote:banner001 wrote:a CDi with a blue L or blue M will be fine.Why do you advize people wen you dont kno the answer, it looks like you just guess alot of the time. Thats not helfull in anyway.banner001 wrote:ok, simple question, are the blue L and blue M CDi's restricted in any way?
Would the yellow v cdi unit still start my bike other than it bring restricted
- KwakKwak
- My Bike: ZXR 400L9 2001
Blue M defo not restricted, FACT.banner001 wrote:its has been stated many times before that the blue L and blue M CDi's are NOT restricted
Yes but will be in 'default mode' and 10,000rpm limit. With a 10k resistor wired in or an 'M max' box (does the same job) unrestricts it and will then limit at 13,800rpm. Unlike the 'L' 14,500rpm (when unrestricted) or the 'M' 14.500rpm which is UK spec and has no speed restriction...as KwakKwak rightly says.clarkiefez wrote:Would the yellow v cdi unit still start my bike other than it bring restricted
R.Middleton
- My Bike: ZXR400
now there are some OEM or duplicate CDI with good quality. it can be a replacement.
