need some help urgently
- My Bike: Kawasaki zxr400 l6
i have just had my bike back from getting the head gasket changed and started it up today and there was water bubbaling from the radiator and thn into the expansion bottle its not over heatting its just like there is air beeing pumped round any suggestions greatly welcome
- CaNsA
- My Bike: ZX6R F1
Re: need some help urgently
***DO NOT DO THIS ON A HOT/WARM ENGINE***
really
Pull the rad cap off, start the bike and look down the filler hole.
if you see a steady stream of bubbles then the head isnt seated correctly and the gasket isnt sealing.
really
they would have drained the cooling system to fit the new HG, might just be small pockets of air being released from inside the cylinder bore/thermostat area, top it up with coolant after squeezing all the pipes to release any trapped air bubbles and see if it happens again.
It seams to get more bubbles as the engin revs and how can i seal the heads
There either an awful lot of air in there or the head gasket hasnt sealed properly.
You can check the head gasket seal with a compression test. If its not sealing then it will more than likely need replacing. But if a show has done it, take it back and tell them what the issue is.
- Restricted
- My Bike: zxr 400 l6
A compression test may not show the head gasket leak, I did one on mine but the head gasket had just gone from the water jacket to the external of the engine, was dripping down the front of the engine onto the exhaust
