My On going project
- My Bike: Unique ZXR400
My On going project
Bought the bike in feb 07, the bike itself was in good but dirty condition, and bodywork had room for improvement. It had a full micron system with an open can and a datatool veto (fit and regret for sure). it had just had:
New Camshafts
New rockers
Shims
Generator re-wind
Carb rebuild
Piston rings
Cam chain
New battery
Unfortuanately the gearbox and clutch where worse for ware
By march 07 I had bought a replacement engine from a H model. This engine had just had :
Head gasket
Shims
Clutch rebuild
CCT
Cam chain
So far (23/03/07) I have polished half of the frame (down to the welds), and tonight I have bolted in the new engine.
New Camshafts
New rockers
Shims
Generator re-wind
Carb rebuild
Piston rings
Cam chain
New battery
Head gasket
Shims
Clutch rebuild
CCT
Cam chain
Andy
Today (28/03/07) the brake pressure switch and rearsets came. Got the switch fitted and thats all good.
Tonight I got it running toward the end of the night (spent the day workin on my CR).
so far the list of done things:
Rearsets
rear brake pressure switch conversion
New engine
silicone rubber HT leads
Modified wiring loom
Semi polished frame
Stainless bolts all round the fairings and lots of missing bolts replaced. Every bolt re-oiled
Removed that bloody alarm
Rearsets
New engine
Semi polished frame
Andy
Here is a more upto date pic of it now
I am now in the throws of doing a service. The aprilia is up for sale and have already had much of my time wasted. As soon as it sells I can attack my want list
[/list]
[/list]
Andy
06/05/07
Today I have been buying the first proper lot of parts
Been getting some bits for the bike today:
Full micron SS with carbon can
Clock bracket
Mirror stay
Bottom end
Front and rear discs
Two lower fairings
Two rear fairings
Various wee brackets
Hoover tube upper
wee little airbox bungs
09/05/07
In addition to the other parts I now have these coming
got a clear led tail light on order.ermax undertray on order.new hanger clamp and slip on clamps have arrived. just need to get some gaskets, and the exhaust can go on
I have also bought a pair of Iridium headlight bulbs
So far we have this
Clock bracket
Mirror stay
Bottom end
Two lower fairings
Two rear fairings
Hoover tube upper
09/05/07
So far we have this
Andy
I have now stripped more aspects
These bits are on their way to the powdercoaters
I have removed some of the Pink aspects
More to come
So far I have bought :
No.2 Engine
Rearsets
Mini LED tail light
New rear subframe
Brake pressure switch
Speedo cable
Can hanger
Mini LED indicators
Slip on clamp
Micron exhaust system + can
Lower fairings
Rear fairings
discs
Clock Stay
Mirror Stay
Bottom end
LED rear light
Undertray
Exhaust gaskets
Top fairing
Replacement headlight
" O/S mirror
To that point the parts cost is £966.16, not including postage.
More to come
No.2 Engine
Rearsets
Mini LED tail light
New rear subframe
Speedo cable
Can hanger
Mini LED indicators
Slip on clamp
Lower fairings
Rear fairings
discs
Clock Stay
Mirror Stay
Bottom end
LED rear light
Undertray
Exhaust gaskets
Top fairing
" O/S mirror
Andy
they are the £99 ACU approved jobbies from ebay. The quality isn't fantastic to be honest. They get delivered straight off the mill, full of swarf and machine oil. The milling quality is poor with some 'dinks' in the surface and some quite sharp areas. The bushes are crap and I doubt they will last as long as a bronze equivalant. Also the holes for the mouting bolts are recessed with diameter 10mm yet no M8 bolt with a 10mm head is easily available, so the standard M8 cap head looks silly in the hole.
The gear linkage rod is also in need of extra washers to space it out or the lever hits it on downshifts.
All in all not alot of work to put right, but for £100 it would be nice if they cleaned off the swarf.
By the way, I have a box of things ready for black powder coat, should I have the rearset done satin black, i think it would look nice, what you rekon?
Andy
- boldaholic
i like goooooollllld!
polish the letters or paint them black ect will look nice!
