New l2 project
- My Bike: zxr400
New l2 project
Hi guys I'm about to take delivery of my zxr I thought I would post some pics as it is now,
- My Bike: zxr400
Re: New l2 project
And 1 more
- My Bike: zxr400
Re: New l2 project
so go the bike in the work shop and set about finding what was broken and what was save able.
and there was a fair bit of damage some i had spotted some was a supprise.
so next i had to start fixing what i could the mirror mount was bent, and was easily straightened with a vice and some brute force will need painting later thought.
same story with both mid fairing brakets,
before.
and after not perfect but much better.
before.
- My Bike: zxr400
Re: New l2 project
Calipers
having decided to change out all brake hoses for hel braded lines, pulling the caliper to cure the binding was a chance that was silly to miss, and boy were there some horrors.
once i split the first caliper i found the pistons were siezed and there were anti-squiel pads in them these turned out to be a massive help on getting the pistons out, i drilled a 5 mm hole through them put a screw in and used a slide hammer to get them out i had to do this on all 8 and i still didnt take a picture
once out it was obvious the fluid was past it and one side had no dust seals in place meaning the fluid seals were weeping,
they are now nice and clean and waiting on new pistons and seals which i am hunting for as the best i can find is £72 per caliper.
i then removed the tail section to fit the new indicatos from bike it, and found quite a mix of fixings had been used.
old indicator.
and the new shiney one
old indicator.
- My Bike: zxr 400l3
Re: New l2 project
Fair play to you mate..... It looks like you've been busy!!!
- My Bike: zxr400
Re: New l2 project
2 days work I'm quite chuffed need it on the road ASAP will prob do body work next winter, once I have decided on a colour scheme.
- My Bike: zxr400
Re: New l2 project
- My Bike: zxr400
Re: New l2 project
- My Bike: zxr400
Re: New l2 project
clutch cable
once the old cable is off this can be done any way you like, how ever the refit i have documented in case any one is a little worried about doing it, firstly we need to oil the new cable.
its a small hole but with care you can get oil in there i use a steady hand and an oil can i keep going untill oil drips from the botttom this way i know ive done my best to maximise the life of the cable.
next there are 4 places the cable must run through, 3 guides and then the lower adjuster,
getting it in to the arm can be fiddly how ever persistance will out
next i had to re assemble the lever this just slides together with some grease,
cable just slides in its easier to do this first,
next it slips through the adjuster and into place in the lever mount,
slide through bolt in and tighten now adjusting the cable is simple, i like to take the lower adjuster all the way to the end and use the upper adjuster for fine tuning i hit a snag in that my clutch plates are stuck together meaning i cannot check the clutch isnt dragging untill i strip it out.
- My Bike: zxr400
Re: New l2 project
- My Bike: zxr400
Re: New l2 project
- My Bike: ZXR 400 L9
Re: New l2 project
Those holes should be filled by rubber bungs. Easily visible in the parts diagram.
92066A - http://www.kawasakioriginalparts.com/ka ... 1999&ca=GB
- My Bike: zxr400
- My Bike: zxr400
Re: New l2 project
right today the piston and seals arrived for the front calipers i upgraded to stainless steel to try and maximise the life of them the pictures tell the story,
i would have re-fitted them but i forgot to pick up my o-ring set from my uncles place so i will finish this job tomorrow, also today my bike skate arrived
once on the skate i striped the clutch apart to investage the issue and found some issues, im having one of the race techs at work take a look but im thinking i will replace it all including springs, and also a fair bit of moisture in threre but im thinking that may be where its been sat for ages.
- Gemini
- cloning technology
Re: New l2 project
red rubber grease in the calipers, good man
i used to swear by that stuff on my 7r!
