New l2 project
Re: New l2 project
do the clutch properly, new steels, springs and plates, all kawasaki OEM.
as for the tape on the airbox, it should be 2 small rubber bungs, part number 920661389
on the LHS of the airbox there should be a drain port, this should have a hose attached to it with a removeable plug at the end, parts numbers are 920591758 and 920661211, looks like you are missing yours, not a big thing, but i prefer to have it.
tink
My Bike: ZXR400 L2
Re: New l2 project
Post by tink »
Looking good nice work
ninjadave1400
My Bike: zxr400
Re: New l2 project
Post by ninjadave1400 »
Thanks for the feed back guys, good grease on a caliper re-build makes or brakes it for me, clutch is being replaced I've gone with ebc as I have used them a lot and trust them, I had no idea I was missing any thing tho, I shall investigate shortly :smt003
ninjadave1400
My Bike: zxr400
Re: New l2 project
ok so this evening, i had to get the new cooling hoses on and fitted i couldnt fit my new coolant bottle as im waiting for my clutch components to arrive,
i have also removed the carbs to get them checked over by the carb expert at work, then i set about find and removing all speed, power and rev restrictions the clockes were apart and the 112kph tab out then i found the ecu below is this the one i want or not ? Cheers
and with some pointers from other i have some bits to order for the air box
kawazonkey
My Bike: Kawasaki zxr400
Re: New l2 project
Post by kawazonkey »
An L or an M CDI is the full oomph one.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: New l2 project
Post by Mori Man »
Wow, you pull that bike out of a river shocking
Great job bringing it back to life :smt023
ninjadave1400
My Bike: zxr400
Re: New l2 project
kawazonkey wrote:An L or an M CDI is the full oomph one.
thats a result then :-)
Mori Man wrote:Wow, you pull that bike out of a river shocking
not a river she was a cat c that been in storage for 2 years
the interesting bit is he had a 33bhp license when it was crashed from reading the file, so the fact it has the full power cdi and no restriction in the carbs begs some questions
Re: New l2 project
I could be wrong, but i think the M CDi gives a 14,800rpm redline, whereas the L CDi gives 14,500? im sure ive seen it on here before?
ninjadave1400
My Bike: zxr400
Re: New l2 project
As long as its not 10,000 I'm happy I've come from a tuned zzr1400 so I need al the help I can get !!
kawazonkey
Re: New l2 project
Love those funky green hoses, where did you get them?
ninjadave1400
My Bike: zxr400
Re: New l2 project
kawazonkey wrote:Love those funky green hoses, where did you get them?
eBay bud they are proper samco hoses about 80 notes
ninjadave1400
My Bike: zxr400
Re: New l2 project
Or the brake lines they are from hel performance 95 notes for all 3 in bolts and washers
kawazonkey
Re: New l2 project
ta for the info!
ninjadave1400
My Bike: zxr400
Re: New l2 project
So due to not having parts to get on with much I cleaned, the head while the carbs are away,
And fitted the R&G bits,
ninjadave1400
My Bike: zxr400
Re: New l2 project
Guys I can't get brakes to bleed I get small amount of preasure if I squeeze lever slow would you agree it's seals in master cylinder ?
