Does your zxr400 have hot starting problems?
Due to the amount of recent posts about hot starting, robB had a good idea that we should list here who has hot starting problems and who doesn't, everyone can join in so we can try and see some sort of pattern.
Please list
Model & year
Air filter Std or other
type & manufacturer of spark plugs
Jet size or carb mods if any
Exhaust system
anything else which may contribute
if we all list in the same manner it will be easier to sort.
Please list
Model & year
Exhaust system
Northern ANdy
- My Bike: Unique ZXR400
- diesel
- My Bike: Zx7r
89 H1 SP
Air filter Std
Not sure bout plugs tbh. will be changing em soon for decent ones .
Standard Jets.
Scorpion Exhaust
New thermostat, manual fan switch.
no carb heaters.
have just rebuilt my bike with another set of carbs, base and head gasket, thermostat, filters etc. ill keep u posted if i still have hot starting probs
hate the hot starting crap.
Air filter Std
Standard Jets.
Scorpion Exhaust
no carb heaters.
- Xphyral
Mogas 64
- My Bike: ZXR 400 L5 1999
L3 39,000 miles
Micron system no baffel all else standard
never once had any starting problems
carb warmers fited
carb warmers fited
- SplaTZXR400
- My Bike: ZXR400
L3 1993
stock filter,
NGK cr9e
stock setup and jetting
standard exhaust system
33,000 miles / 444bore
carb heaters
random hot starting problems aswell as lots of other problems with my lemon. [edit/update>>] since new coils, no more problems starting warm, but when hot it either needs, a few quick blips of the starter or open throttle. anything other than hot, straight of the button. [<<edit/update]
stock filter,
NGK cr9e
carb heaters
gubbs
- My Bike: ZZR1100C3
stock filterSplaTZXR400 wrote:L3 1993
stock filter,
NGK cr9e
NGK cr9e[K]
102 main jets
ported and gas flowed
13:1 compression
44, 000 km's
basically will not start off the button when hot
I suspect this is just increased friction on the starter gear due to incorrect gasket (combination of cereal packet and mank) on the alternator cover.
ordered a new gasket, will see!
zxr400 h2 (breaking)
zzr1100c3 (broken)
Vespa et4 (almost broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
Can we start listing if you have carb heaters? Or if you have already posted edit your post. Youll know carb heaters as there will be a tube that links from the pipe by the genny cover upto the carbs and then out the other side and back into the engine block.
looks like this, see the green bottle type thing? Thats the tube thats routes coolant to the carbs to heat them up.
good point robB
- SplaTZXR400
- My Bike: ZXR400
