Hi all, i hope you can help me. I am working on a hybrid, I bought what should be H forks and yokes but today I fitted them into the bike. The yoke went in fine then I dropped the forks in the bottom again without problems, next I went to drop the top yoke on and it wont fit. the spacing is wrong somewhere. I know there are differences in the the H & L models so any idea how I can identify the yokes? and for that matter the forks as i now need to get a wheel spindle and speedo drive. I suspect I have a mix of bits.
Thanks, Phil
Yoke differences.
Re: Yoke differences.
Ok just to prove i have been searching , I can confirm it seems I do have H forks as mine are 780mm long. But just to confuse me I read that the H and L are different diameter, so it then seem my yokes can be a mix of H and L as the both fit. Is this right or have I mis-read something. Also what is the difference with wheel spindle and wheels? I need to match it all I assume.
Thanks again.
Thanks again.
