Hi everyone,
I created a small website to share a simple NOTE SHEET I created : the purpose is to help people doing the valve clearance check on a SHIM BASED ENGINE.
I did my clearance check on my ZXR 400 a few weeks ago and thought this kind of sheet could help doing this. This no not so hard to do but boring and you can quickly make a mistake on a shim swap.
Hope this will help some of you ! You can access the free download page with a CLICK here :
http://gearsandcoffee.com/file-download.php
Just choose if you have a 2 or 4 valves per cylinder engine, and print !
yogi
Valve clearance NOTE SHEET to help doing a SHIM SWAP (download)
- My Bike: 400 ZXR L3
Get a FREE EASY SHIM NOTESHEET to check all your valves clearance with ease :
