As far as I am aware that is the F3 spec CDI as the SP road version has 3673 stamped in that location. This ignition would have come in the race kit. there is not a huge amount of variation between the two unless it was a special kit version from the factory.
Was just looking through some parts and found a harness I bought a couple years ago with an "N" CDI. I'll shoot a photo and post it up soon. Would "N" be an SP cdi?
i have just fitted an 'L' uk spec speedo to my h which has the denso cdi unit with red/silver sticker...anyone know if this will be restricted or am i just going to have to find out the old fashioned way (on private land of course)?
Tom mccrea wrote:sorry to drag up an old thread...but...
Yup, exactly what I have done. Need a speed restriction off box or by-pass to stop.
With no signal the CDI will also rev restrict to 10K RPM giving you a top speed of 112mph in 6th gear !
MM!
Nothing worse than having an H and not being able to scratch it ! Living life on the edge,SuPposedly
The H should have been restricted to 112 / 180kph anyhow unless the old speedo had been messed with OR you already have a de-restriction box on it (you can derestrict it either way)?
Have a look by the speedo, theres a plug that connected to your old speedo, is this free now and unconnected?
Sorry for reviving a old thread. Would I be able to fit any CDI to my zxr400? I have a H model but the single seat one with the flatslide carbs. CDI is missing...
