Would anyone be able to post the length of the CBR 600 sticks along with the dismeter I can't tell if they will fit my 250 but if they would I'd imagine it'd run much much better . I would be a bit concerned if they will spark fast enough but it's worth a shot . Thanks guys
Sent from my Redmi 5 Plus using Tapatalk
Thought i recognised that username
Ive sold my stick coils that i had on my 400, but ill go and do a quick "by eye" reckoning for you tomorrow and see on my zxr250 if i think they would have fit (from memory of what they looked like)...
Yours truly has returned [emoji23]
That'd be great id appreciate that it would help free up some space in my zxr hopefully get to to run
Can I tell me what Stick Coils will fit a ZXR 400 L9?
i have,12volts at all 4 sticks,top and bottom,but no spark at plug tip?have tried the the ignitor from my other zxr400 track bike,but no luck,no spark,the crank sensor,i have tried from the other 400,but again no luck,i have total loss ignition,from your diagram,i have power at the clocks-oil light-n/light-fan-rad sensor-and starter motor,but no spark,i hope this helps ?
If you have 12V at the coils/sticks, and you have connected your pickup coil then your CDi is dead or you have a break in your wiring, or someother issue, I. E. No resistor on grey wire, or dead plugs
If its a full total loss loom there is very little to it, and if its not giving a spark with the original coils then it's likely a CDi or loom wiring issue.
Has this loom ever worked since you created it?
hi, banner,zxr400 L no spark,found the problem made my own new loom,had got my ic wires crossed,runs nice ,my thanks for your help.
