does anyone know how much heavier the h1 swing arm is compard to the h2.
im wondering because there is all the extra bracing so it must be heavier?
has anyone done a swap?
H1 swingarm to h2 swingarm swap
- motoxxx
- My Bike: ZXR400 H1 Race bike
- jake
Re: H1 swingarm to h2 swingarm swap
yes, they are a fair bit heavier. Im not sure how much, but you can tell when you pick them both up.
Dont forget they use different wheel spindles and a different rear caliper hanger
- motoxxx
Thanks for the reply
Ill hopefuly be changing them next weekend so will weigh and post the difference up then
- motoxxx
changed the swingarm over from h1 to h2 today
found that the h1 swingarm is heavier by 1.5kilos
- jake
that much? sweet, good saving then
