valves
kermit the frog
My Bike: zxr400 L9
valves
Post by kermit the frog »
morning guys, do you racers recommend check/adjusting valve clearances at 21000 miles if it hasnt been done yet??? also i havnt had the engine apart yet but i cant find the buckets and shims on a diagram of the valves????????????????????? cheers. merry xmas.
never give up!
Re: valves
kermit the frog wrote: i cant find the buckets and shims on a diagram of the valves????????????????????? cheers. merry xmas.
:smt003 :smt003 :smt003 :smt003 :smt003 :smt003
Thats because there aren't any
ZXR400s have rockers that operate the valves.
And yes you need to have checked the clearances......................
kermit the frog
My Bike: zxr400 L9
Re: valves
haha. so i guess from previoes experiance you just adjust with a screwdriver.
never give up!
Re: valves
nope, no screwdriver and locknut, you need to adjust the shims. Its a case of measuring the clearance, then the shim, and then working out how much larger or smaller the new shim has to be. Some can be set by swapping shims from the other valves.
jamkwak
My Bike: ZXR400L EX WORKS KAWASAKI
Re: valves
Post by jamkwak »
Measure the gap between the shim and rocker face..the clearance sizes are in the manual, I think it's 15 for inlet and 20 for exhaust...
You can slide the rocker to one side and lift out the shims with a small magnet, be extremely careful not to lose one down an oil channel or get it stuck behind a spring..
The sizes are normally marked on the shim or you can measure with a micrometer or calipers
i.e 2.85mm,2.9mm,2.95mm,3.0mm etc
They can be quite pricey.. Kawasaki about £6 each or Wemoto £3.50 each
kermit the frog
My Bike: zxr400 L9
Re: valves
cheers guys, all done and they didnt need adjusting. luckily. lol
neway im derestricted now so il be rackin up the miles as of tomorrow. :tease
never give up!
