ZXR 400 dynojet problem
belmondo666
My Bike: ZXR 400 L9 track bike
Post by belmondo666 »
Hi guys.. I have a problem. I have installed DYNOJET Stage 1 on my bike as per the instructions. The main jet 96 and the needle on the two groove from the top, fuel composition for 2 turns, floats for 11mm. A motorcycle up to 7000rpm is screwed in by rotation, while already over 7000rpm the engine stops and does not screw in, shoots from the silencer. I set the needle to the last notch and a little better, but still this mid range has too much fuel in my opinion. What do you think about this? I don't know if it makes sense to change main jet 92, or just go back to the original needles. :smt017 :smt017 cgeek :smt017
Hecki
Re: ZXR 400 dynojet problem
Post by Hecki »
use the oem needle, the dynojet stainless steel kills the brass needle seat.
with aftermarket exhaust, air filter or stock, use 92 main jet. bike run lambda 0,9-0,95 i measured with LSU 4.9 o2 sensor.
