Hi all,
this is going to sound like a stupid question I know, but when removing carbs and undoing the clamps round the inlets, do they need to come right off? Everything else is disconnected, iv'e loosened the clamps and tried lifting the carbs off, but while they move a little they will not come off. I have checked the manual and can't see anything ive missed, also it doesn't say they need to come right off.
Are they usually really tight?
I don't want to break anything.
Paul
Removing carbs
- Dominik
- My Bike: Zxr 400 L3
Re: Removing carbs
It is pretty hard to remove them but if you undid the clamps properly you shouldn´t have a problem. Just tilt them backwards and the carbs will plop out.
Otherwise you could remove the whole inlets. However it´s pain in the ass to remove the bolts with carbs on them
Zxr 400 SL - 130kg
- Miles
- My Bike: ZXR 400 L3
Re: Removing carbs
The rubber inlets do not need to come off, just loosen the clamps and work the carbs free. They could be stiff if they haven't been off in awhile
- My Bike: Yamaha R1
Re: Removing carbs
Thanks guys, at least I know they are stiff so know what I'm up against before I break something. Yes the clamps are definitely undone and loose.
It did start rocking them back and forth but didn't seem to be lifting at all. Will give it another go.
I won't undo the inlet bolts as they look like a pain with carbs there, sod that lol.
Re: Removing carbs
It's easy when you know how eh, thanks for that DominikDominik wrote:It is pretty hard to remove them but if you undid the clamps properly you shouldn´t have a problem. Just tilt them backwards and the carbs will plop out.
