Help needed on sprocket setup
p.lally
My Bike: ZXR400 H2
Post by p.lally »
Hello, I am needing some advise on sprocket setup, I am currently building a bike which I intend to use on the track.
I am wanting it set up more for acceleration rather than top speed (but not that much it runs out of go)
Can anyone please advise on which setup to go for???
I'm thinking of 14/47
kawazonkey
My Bike: Kawasaki zxr400
Re: Help needed on sprocket setup
Post by kawazonkey »
What tracks are you racing on? Different set ups for different circuits!
p.lally
My Bike: ZXR400 H2
Post by p.lally »
kawazonkey wrote:What tracks are you racing on? Different set ups for different circuits!
Hi, hopefully first one on this bike at cadwell (next month), but then probably any of the ones up North, Anglesey, oulton park or donnington
wes
My Bike: ZXR 400
Post by wes »
I used 14-46 for Donny and Brands Indy
15-46 for faster tracks like Snetterton and Silverstone
wes
My Bike: ZXR 400
Post by wes »
Use search here to find other tracks and posts....
stuzx4r
My Bike: zxr400sp race bike
Post by stuzx4r »
hi, obviously the amount of tuning and more importantly how hard you ride will affect what your gearing you require, however for both Oulton and Cadwell I would suggest 14/48.
(I'm assuming your on a standard L gearbox)
Good luck and have fun.
Stuart.
p.lally
My Bike: ZXR400 H2
Post by p.lally »
stuzx4r wrote:hi, obviously the amount of tuning and more importantly how hard you ride will affect what your gearing you require, however for both Oulton and Cadwell I would suggest 14/48.
Stuart.
Hi and thanks, I am looking to hit cadwell shortly and I have just bought a 14 and 47. My bike is a h2 model.
Peter
stuzx4r
Post by stuzx4r »
Hi Peter, you will be in the correct area with 14/47, it will probably feel as though its to short as you bimble round for the first couple of laps, but once you have it opened up at reving to 15k it will be fine. H2 gearbox is very close to the common L box so you will be fine, its only the H1 that's shorter.
Have fun, Stuart.
I like to have a selection of sprockets to choose from. I've got rears from 40 up to 50 and fronts from 13 to 16
After an initial estimate and lap or two I can then select the best set up from the options available.
What you're actually trying to do is get the gearing so that at the end of the longest straight the bike is 6th gear on your bikes red line and your just about to brake for the next corner. You can of course play with the gearing to suit a particular section but that will come at a cost elsewhere.................as ever there is a compromise to be had.
Wind speed and direction can be a factor too as can wet or dry track conditions
400y
My Bike: ZXR400H1 GSXR600
Post by 400y »
Cargo - what gearing do you run at Armoy on the 400?
400y wrote:Cargo - what gearing do you run at Armoy on the 400?
Good question. I've only done it once and I don't think I have a note of it in my book
Prob something tall ish Tandragee gearing might be a decent starting point.
