damper,
- My Bike: 1988 ZX400-F3
Re: damper,
http://www.fastfromthepast.com/servlet/ ... Categories
The ODM2000 and the ODM3000 both fit the ZXR.
Stroke lengths are 120mm and 130mm
Damper body length shouldn't matter as long as the stroke is correct, both of the above are under 400mm though.
- Tirpitz
- My Bike: Kawasaki ZXR400L4
Re: damper,
See viewtopic.php?f=123&t=12273
Unless your lock stops have been modded even a 140mm stroke isn't long enough to prevent the damper acting as a lock stop (a scrutineering fail). Easy to mod the stops though by drilling through and inserting bolts. For racing you don't need the OEM lock to lock travel.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Re: damper,
so 120 and 130 is no good? i take it?
thanks
thanks
Re: damper,
viewtopic.php?f=87&t=12363
Mori Man wrote:Mine is the ODM3000 but you can use the 2000 too:ZX4R-F3 wrote:Hi Mori man,
Which model NHK Damper have you fitted to your H also what stroke length has it got.
Andy
http://www.fujita-rc-engineering.co.jp/ ... k/nhk.html
http://www.fujita-rc-engineering.co.jp/ ... asaki.html
It's got to be 6~7yrs old now and still no problems with it , the Posh-Faith one I have on the ZRX is starting to leak so is in need of a service.
MM!
- Tirpitz
Re: damper,
It's not that. Both of those will work but you will need to mod the lock stops as the dampers are too short to allow the full OEM lock-to-lock travel. I would think that either of them will give you sufficient lock for racing (unless you are thinking of doing an enduro on it )zxr500man wrote:so 120 and 130 is no good? i take it?
thanks
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Re: damper,
so in other words they wont fukin work.
- Tirpitz
Re: damper,
Are you hard of understanding or something?zxr500man wrote:so in other words they wont fukin work.
THEY DO WORK YOU JUST HAVE TO MODIFY THE LOCK STOPS TO SLIGHTLY REDUCE THE LOCK TO LOCK TRAVEL.
Is that any clearer?
I have a 140mm one on my bike and it works fine.
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Re: damper,
You idiot,if it worked properly you would not have to mod anything,this is why im asking what is the proper lenght.
So I dont have to do what you did.
:wanker
:wanker
Re: damper,
so that's where i've been going wrong all my life, not calling someone who answers my question a wanker?
I'll be at the top of the promotion ladder in no time!
Re: damper,
Well I am totally confused with most posts in this !
The NHK kits need NO MODIFICATIONS - FULL FUCKIN STOP !
Bolt n Go like on my bike, is that so difficult to understand ?
- Tirpitz
Re: damper,
You clearly have no manners whatsoever. Someone who you don't know from Adam has taken the trouble to try and help you by answering your query and you first start be snappy and rude and then become completely offensive. Help yourself in future, welcome to my ignore list.zxr500man wrote: You idiot,if it worked properly you would not have to mod anything,this is why im asking what is the proper lenght.
:wanker
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Re: damper,
You did not answer it correctly,your answer did not make any sense,
and you were just as rude yourself,
Maybe you didn't understand my question or something,but there's no need for for you to be insulting and offensive!
Re: damper,
sorry zxr500man, but there's no way you're going to win this argument - you engaged the hostilities and the only thing you're going to do by blaming other people is piss them off
Now lets all grow up and you say sorry and we all move on rather than making a mountain out of a mole hill
Re: damper,
Bollox , bring on the Mountains
