Hi guys
I have a H2, I have seen sets of down tubes for the L model everywhere. Does anyone know if the L tubes match the H tubes?
ZXR400 down pipes
Re: ZXR400 down pipes
They do fit but they are more restricted (diameter of pipes are a bit less).
Spend your money on a full aftermarket system - I had a Moriwaki on my ZRX when I bought it with no carb adjustments, I then moved onto a Daishin and all we done was richened the mixture.
Some sytems do need jetted and all need jetted to get the best out of them , unless your mad keen keeping the bike stock don't fit OEM. If a can is too loud stick a db killer in it - that will also richen the mixture too.
MM!
MM!
