Came across a zxr 400 race bike with the oil cooler removed...
What are the benefits of this ?
Is it simple to remove ? Or are there any extra things I have to do ??
Oil Cooler Removal
- My Bike: ZXR 400L
Oil Cooler Removal
[b]Racing is life, anything before or after is just waiting[/b]
Re: Oil Cooler Removal
use the search...................loads and loads and loads to read
Couldnt be easier. 4 bolts to remove and then either a blanking plate to cover the two oilwaysBen Coyle Racing wrote:Came across a zxr 400 race bike with the oil cooler removed...
Benefits - weight and much easier race engine handing/ changes
- My Bike: ZXR 400L
So are there any downsides to having no oil cooler ?Couldnt be easier. 4 bolts to remove and then either a blanking plate to cover the two oilwaysor alternatively (if a blanking plate is a problem) - cut the two elbows off the oil lines, crimp the ends, fill with chemical metal and (after its set) whack em back on where the used to be - job done.
So as I'm concerened there are NO downsides.
But please use the search read the full threads and make your own mind up
- My Bike: ZXR 400L
Ok I get the point to next time use the search bar first, im new to this site so i'll know from now on.
Cheers for the replies guys
Seems a pretty simple job so i'll hit it tomorow !!
