carbon tank cover
zxr500man
carbon tank cover
Post by zxr500man »
Just got it,
its not perfect ,but its not bad,the guy is a beginner,
but its very strong and light!and cheap!
my origonal tank weighed 5.5 kg on my bathroom scales,
this doesent even register!
now i have to desing an alloy tank any tips much appricated,i was thinking about putting a hinge on this tank cover.
not sure. :excited
Re: carbon tank cover
Nice! How much? And how does it fit on?
zxr500man
Post by zxr500man »
he gave me two brackets,im to glue them to the inside the cover,their l shaped,i can bore the brackets to suit,their carbon too.
sinap
Post by sinap »
Ben Palmer, raven performace does the ally fuel tanks.they are shaped to fit behind the airbox and hold about 5ltrs.
zxr500man
Post by zxr500man »
ally ,is that short for aluminium?
might just make my own up ,if theres a mistake ,i can only blame myself. :smt001
AFM327
Post by AFM327 »
Anyone tried making a small carbon tank? I was thinking about making one for my 400. The plan was to carve a foam block to make the form, and then make the molds off the form. I saw 5 miles per liter mentioned earlier, is that a good estimate for mileage, short course or road course?
zxr500man
Post by zxr500man »
would the petrol not melt the resin that holds the carbon fiber together,not imediatly but after a while .?
I think that would depend largely on the resin used.
AFM327
Post by AFM327 »
No it won't melt the resin, I have a friend who makes them and he hasn't had any issues. And since we'll just be making it to fit under the tank cover it doesn't have to be pretty either. :) How are most of the small aluminum sprint tanks bolted to the frame?
zxr500man
Post by zxr500man »
well if thats the case i might get my buddy to make one for me,
i dont know where im going to bolt any thing,i need to get a ram air box first ,just to see what space i have,
it would be that bit lighter being made from carbon too,
AFM327
Post by AFM327 »
You could make the air box our of fiberglass, it's much cheaper and will work just as well.
zxr500man
Post by zxr500man »
your right,its just that iv read here some where it has to be a certain shape,
like i would have thought ,if it was really wide at the front to catch as much air as possible,and then a small area around the carbs,
i thought that would create as much down force as possible ,but it turns out not its acturally supose to be a pretty big area around the carbs,
any way i just wouldnt be sure about it,i got a quaote yesterday for 140 including bellmouths from dyno pro racing,
so i think i might go with that,my bike is a h model so i could not find a second hand one.
