I read that the redline in M is 14500rpm and no top speed limit, it is correct?
Any advise is help.
Thanks,
Andreas
Greece.
mark400 wrote:I am also interested in this type of C.D.I....
We had an electrical issue at Brands yesterday, and (among 10 other things :smt013 ) we changed the C.D.I. to a spare. By the end of the day, we had used 2 blue C.D.I.'s with the letter "L" on the sticker, and another blue C.D.I. which had the letter "M".
We forgot which one, but my brother was sure that the bike would rev through the red line with one of these C.D.I.'s fitted ! Is it likely that one of the boxes has a higher limit ( I also have C.D.I.'s with a red sticker, and one with a yellow sticker, but these limit the revs noticeably) - Or has it been modded by someone ( like Roger does ?) ?
Answers on a postcard.....
Because I am not a tunerzimm wrote:http://www.ignitech.cz/english/aindex.htm
you want a 2ch tcip4 and tell them whether its for an L or an H (affects the loom adaptor supplied)
cheap, programmable, reliable ..
job done.
of the stock ones, for an L you want a 21119-1332 M (uk spec) as stated in previous posts. iirc, 14,800rpm limit, no speed restriction circuit
i have some kit ones for an H .. 21119-1296 i think.. they're better...(15,200rpm limit, different advance curve, need kit rotor) I dont use them though
Why don't you use a RAM airbox? This will give you more power for sureGas flow head skimmed.
Kit Pistons
Stock cams (try to find SP but nothing yet...)
Dynojet carbs
Stock airbox with free flow filter
Full exhaust custom system copy kit.
