hi guys,
does anyone know which 6 pot callipers will bolt str8 onto the zxr400?
ive seen some billet ones on ebay but they are gettin a bit pricey, do zxr750 or 600 callipers bolt str8 on?
any help appreciated
al
6 pot callipers
6 pot callipers
A J Racing
http://diesel001.users.btopenworld.com/Conversions.html
Not sure if you can buy 6 pots for the F model or weather they 6 pots anyway, but heres a start
the only thing to alter is the mounting bolts, your zxr400 uses 8mm bolts the suz only has 6mm. you can either tap out the bolt holes on the calipers to 8mm or usu bolts with collars (like brake disc bolts). hope this helps. good luck.
