SP CDI and Loom
Re: SP CDI and Loom
I dont know if you are aware of this Davw but there are some restricted sp igniters...and i dont mean on the speed restriction side, that can be overcome with a 10k resistor. They have an ignition retard programed into them that retards the timing at about 12,000rpm, they will continue to rev on to 15,300rpm but the power just drops off after 12k...rendering them useless! it would need an electronics 'wizzkid' to sort it out and i havent come across anyone that can sort it in the last 10years.
R.Middleton
Re: SP CDI and Loom
Hi - thanks for the heads up on that. Any idea if that is identifiable from the serial numbers? What was the purpose of the retardation - any idea?rmkd177 wrote:I dont know if you are aware of this Davw but there are some restricted sp igniters...and i dont mean on the speed restriction side, that can be overcome with a 10k resistor. They have an ignition retard programed into them that retards the timing at about 12,000rpm, they will continue to rev on to 15,300rpm but the power just drops off after 12k...rendering them useless! it would need an electronics 'wizzkid' to sort it out and i havent come across anyone that can sort it in the last 10years.
- coley
- My Bike: zxr400 racebike
Re: SP CDI and Loom
I think the serial no. on the one Roger is talking about ends in 73. The 'good' one ends in 72. I'm sure someone will correct me if I'm wrong. Ben
Re: SP CDI and Loom
Ben - thanks for that - mine is serial no 3672 so fingers xdcoley wrote:I think the serial no. on the one Roger is talking about ends in 73. The 'good' one ends in 72. I'm sure someone will correct me if I'm wrong. Ben
Dave
- My Bike: ZXR400 , ZXR950
Re: SP CDI and Loom
How did you get along with this. If it is the F3 spec one you would like I can modify yours to suit. One needs not be a WIZKID just an old hacker...LOL....cheers
Regards TK400
Regards TK400
