runing in new engine
hi guys im just building a zxr4l race bike up an its got new pistons rings cam chain ect wots the best way 2 run her in??ive hurd so many diferent ways<low revs up a hill under load>run in oils? 50kms under 7000rpms or reving the crap out of her as soon as it starts after oil prs is up? thanks
Run it in how your tuner tells you is best
We start at 7 thou then just build it up then nail it in the last session
Dont warm it up to much before you get to the track wait till a track day then warm it up well then just build it up all day dont run around to slow or in to high off a gear you want the engine pulling all the time
You are right every one says different things that is why you should ask your own tuner you can run them in on the dyno we have before as we run out off time
Good luck
Good luck
- richie400ss
- richie400ss
