the spec is as follows
l9 motor
0.5mm skim
no base gasket
unshrouded valves
very light head work. casting marks and steps cleaned up, no material taken out from anywhere.
sp inlet 105
standard exhaust cam .
1208 rods
blue springs
micron headers mated to an r1 50mm link pipe
mark hill can.
32mm cvk's 102mains n77r needles
standard airbox,
inlet rubbers matched
standard inlet trumpets lightly opened up from the shrinkage that these seem to suffer from
advanced ignition (by slotting the pickup)
bit dissapointed with the torque figure should this be higher? or is it because its only a 400?
